Probably a really daft question but I’m following the this tutorial to get basic mail alerts working https://www.unixe.de/icinga-2-icinga-director-and-notifications/
I’m at the point where I need to add the object NotificationCommand “Service Alarm By Email” to director. Is there any way of cutting and pasting the content into a file and have director pick it up from commands.conf if that is in fact the correct file? If not, any ideas which file I should be adding the content to given the list below?
I assumed there would be a single commands.conf but having looked I’ve got a few? Messed around with adding it to a couple of the files below, restarted icinga2, but thinking about it didn’t restart apache for icingaweb2? Wondering if that’s what i’ve done wrong?
root@localhost:/var/lib/icinga2/api/packages/director/localhost-1554290594-9/zones.d/localhost.domain.com# find / -name commands.conf
/var/lib/icinga2/api/packages/director/localhost-1554290594-9/zones.d/localhost.domain.com/commands.conf
/var/lib/icinga2/api/packages/director/localhost-1554290630-9/zones.d/localhost.domain.com/commands.conf
/var/lib/icinga2/api/zones/locakhost.mandogroup.com/director/commands.conf
/etc/icinga2/conf.d/commands.conf
