Continuous increase of storage since Upgrade 2.13.7 --> 2.14.0
    r2.14.0-1
  • Operating System and version
    rhel 8.8
  • Enabled features (icinga2 feature list)
    Enabled features: api checker ido-mysql influxdb2 mainlog notification
  • Icinga Web 2 version and modules (System - About)
[2023-10-30 14:09:28 +0100] information/cli: Icinga application loader (version: r2.14.0-1)
[2023-10-30 14:09:28 +0100] information/cli: Loading configuration file(s).
[2023-10-30 14:09:28 +0100] information/ConfigItem: Committing config item(s).
[2023-10-30 14:09:28 +0100] information/ApiListener: My API identity: vie02s810.vie01.local
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 309 Comments.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 57 Users.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 19 UserGroups.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 2 TimePeriods.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 14 ServiceGroups.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 335 Zones.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 9461 Services.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 8 NotificationCommands.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 21 Notifications.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 582 Hosts.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 89 HostGroups.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 333 Endpoints.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 66 Downtimes.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 3 ApiUsers.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 328 CheckCommands.
[2023-10-30 14:09:28 +0100] information/ConfigItem: Instantiated 1 Influxdb2Writer.
[2023-10-30 14:09:28 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2023-10-30 14:09:28 +0100] information/cli: Finished validating the configuration file(s).
Hi I noticed a distinct continuous increase of the influxdb since my upgrade from icinga 2.13.7 to 2.14… Here a snippet of the relevant updates made:
icinga2-2.14.0-1.el8.x86_64
icinga2-2.13.7-1.el8.x86_64
icinga2-bin-2.14.0-1.el8.x86_64
icinga2-bin-2.13.7-1.el8.x86_64
icinga2-common-2.14.0-1.el8.x86_64
icinga2-common-2.13.7-1.el8.x86_64
icinga2-ido-mysql-2.14.0-1.el8.x86_64
icinga2-ido-mysql-2.13.7-1.el8.x86_64
According to Grafana the continuous increase started exactly when the upper packages were updated.
The influxdb version and the influx settings like retention policy or the like stayed the same. Nothing has been changed on the system regarding influxdb.
Update: I rechecked the retention policy of the icinga-bucket which is mainly a 1:1 mapping of metrics for 365 days and all data is removed after 365 days as expected/configured.
Can someone guide me to find the reason why the influxdb is significantly increasing? Maybe before I run out of storage :slight_smile:
I’d check the logs before the upgrade to see if there were some perfdata discarded due to incorrect format. And/or this bug fix which now produces more or larger time series.
Hi, unfortunately I could not find any logs before this event on 20.09. However I had this problem once and this was fixed as far as I can remember. Apart of that I found a debug.log from August and there were no logs regarding incorrect format (which however is not really representative since these are logs from 5minutes).
Regarding the second bug I doubt that this explains a increase of 25% of storage-space.
So far I compared some time-series data before and after this event and they all seemed ident, so if something in the time series has been changed then all time-series data in the bucket must have been changed at once but the increase on the 20.09 would be massive in such a case if you put the continuous increase of storage (from last month) in relation.
Here the influxdb2.conf
 * The Influxdb2Writer type writes check result metrics and
 * performance data to an InfluxDB v2 HTTP API
object Influxdb2Writer "influxdb2" {
  host = "127.0.0.1"
  port = 8086
  organization = "ORG"
  bucket = "icinga/default"
  auth_token = "ddddddddddd
  host_template = {
    measurement = "$host.check_command$"
    tags = {
      hostname = "$host.name$"
      alias = "$host.display_name$"
  service_template = {
    measurement = "$service.check_command$"
    tags = {
      service = "$service.name$"
Until now the data is still increasing at the same pace. Thank you for your hints!
