pluhin
(Serg P)
1
Hi Team.
Can I create constant as dictionary in icinga2?
example
const CONST_01 = {
"labci_upstream-01" = ["url_01", "80"]
"labci_upstream-02" = ["url_02", "80"]
call it in service-loop-creation?
Looks like does not work for dictionary type, only for list and string
Al2Klimov
(Grandmaster)
2
Hello @pluhin!
What do you mean with “[it] does not work for dictionary type”?
<1> => const d = {}
null
<2> => d
<3> =>
Please share an actual Icinga config which doesn’t work.
Best,
AK
pluhin
(Serg P)
3
Hello @Al2Klimov
Config file:
const MS_UPSTREAMS_lab_ecx = {
"labci_upstream-1" = ["lab_10.com", "80"]
"labci_upstream-2" = ["lab_20.com", "80"]
for ( connect => item in MS_UPSTREAMS_lab_ecx ) {
apply Service "check_connect_" + connect use (connect,item) {
import "generic-service"
import "muted-service"
display_name = "Connection to VIP " + connect
check_command = "tcp"
notes = "Check connection to " + connect
vars.tcp_address = item[0]
vars.tcp_port = item[1]
vars.service_check_type = "external_connect"
assign where match("*Kubernetes*", host.name)
ignore where match("*_Kubernetes_Kafka_*", host.name)
During compilation i have:
[2021-04-28 13:43:28 +0000] information/cli: Icinga application loader (version: r2.12.2-1)
[2021-04-28 13:43:28 +0000] information/cli: Loading configuration file(s).
[2021-04-28 13:43:29 +0000] critical/config: Error: Error while evaluating expression: Tried to access undefined script variable MS_UPSTREAMS_lab_ecx
Location: in /etc/icinga2/zones.d/global-templates/services/MS_K8s/upstreams/check_upstream.conf: 1:25-1:44
/etc/icinga2/zones.d/global-templates/services/MS_K8s/upstreams/check_upstream.conf(1): for ( connect => item in MS_UPSTREAMS_lab_ecx ) {
/etc/icinga2/zones.d/global-templates/services/MS_K8s/upstreams/check_upstream.conf(2): apply Service check_connect_ + connect use (connect,item) {
/etc/icinga2/zones.d/global-templates/services/MS_K8s/upstreams/check_upstream.conf(3): import generic-service
[2021-04-28 13:43:29 +0000] critical/cli: Config validation failed. Re-run with icinga2 daemon -C after fixing the config.
pluhin
(Serg P)
4
But if I change const to var, all work fine
Al2Klimov
(Grandmaster)
5
What do you need it to be constant for?
pluhin
(Serg P)
6
@Al2Klimov
I would like to put constant to separate file. And time-to-time regenerate it by pipeline
Al2Klimov
(Grandmaster)
7
Does globals.MS_UPSTREAMS_lab_ecx = { ... } work for you?
pluhin
(Serg P)
8
Same
[2021-05-03 10:56:24 +0000] information/cli: Loading configuration file(s).
[2021-05-03 10:56:24 +0000] critical/config: Error: Error while evaluating expression: Tried to access undefined script variable MS_UPSTREAMS_lab_ecx
for variants
const globals.MS_UPSTREAMS_lab_ecx = {
and
in separate file
pluhin
(Serg P)
9
I did changes only in constant name, maybe need to change name in call of it in loop?
Al2Klimov
(Grandmaster)
10
What’s the separate file’s name?
pluhin
(Serg P)
11
icinga2-config git:(E2E_SI_LAB) ls -l zones.d/global-templates/services/MS_K8s/upstreams
total 16
-rw-rw-r-- 1 pishchyk pishchyk 611 mei 3 12:44 check_upstream.conf
-rw-rw-r-- 1 pishchyk pishchyk 8218 mei 3 12:55 lab-ecx.conf
assign where ( match("*Kubernetes*", host.name) || match("MT_tst_Kube_MS*",host.name) )
lab-ecx.conf:
const globals.MS_UPSTREAMS_lab_ecx = {...}
Al2Klimov
(Grandmaster)
12
What if you start the name with a capital L?
pluhin
(Serg P)
13
What do you mean? Use capital L where?
pluhin
(Serg P)
15
Some progress, now is
[2021-05-03 15:58:26 +0000] information/cli: Icinga application loader (version: r2.12.2-1)
[2021-05-03 15:58:26 +0000] information/cli: Loading configuration file(s).
[2021-05-03 15:58:27 +0000] critical/config: Error: syntax error, unexpected globals (T_GLOBALS), expecting T_IDENTIFIER
Location: in /etc/icinga2/zones.d/global-templates/services/MS_K8s/upstreams/Lab-ecx.conf: 1:6-1:12
pluhin
(Serg P)
16
Change variable to
const MS_UPSTREAMS_lab_ecx = {...
in file Lab-ecx.conf
looks like works
@Al2Klimov , thank you, but why we need to use capital in file name? do we have documented this “feature”
Al2Klimov
(Grandmaster)
17
Config files seem to be sorted alphabetically and L < c, so the constant is set up before its usage.
