I had a previous installation of icinga2 2.9.1 and monitoring with IDO
I had some difficulties migrating to icinga2 2.12.1 but I finally have that working using Monitoring and IDO.
The installation of icingadb did not create an icingadb database and it isn’t clear to me if it should have.
I have these tables in my mysql database (MariaDB 10.3.14)
| Database |
| director |
| grafana |
| graphite |
| icinga |
| icingaweb2 |
| information_schema |
| mysql |
| performance_schema |
| reporting |
| sys |
| test |
11 rows in set (0.000 sec)
I have been through the icinga DB docs and searched the forums but I am unable to figure out what went wrong.
Should an icindadb database been create or should icingadb use the icinga database?
This is what I see in the log from trying to start icingadb
Jan 16 06:49:54 systemd: Starting Icinga DB...
Jan 16 06:49:55 icingadb: Starting Icinga DB
Jan 16 06:49:55 icingadb: Connecting to database at 'localhost:0'
Jan 16 06:49:55 systemd: Started Icinga DB.
Jan 16 06:49:55 icingadb: Error 1146 (42S02): Table 'icinga.icingadb_schema' doesn't exist#012can't check database schema version#012github.com/icinga/icingadb/pkg/icingadb.(*DB).CheckSchema#012#011github.com/icinga/icingadb/pkg/icingadb/db.go:106#012main.run#012#011github.com/icinga/icingadb/cmd/icingadb/main.go:77#012main.main#012#011github.com/icinga/icingadb/cmd/icingadb/main.go:36#012runtime.main#012#011runtime/proc.go:250#012runtime.goexit#012#011runtime/asm_amd64.s:1598
Jan 16 06:49:55 systemd: icingadb.service: main process exited, code=exited, status=1/FAILURE
Jan 16 06:49:55 systemd: Unit icingadb.service entered failed state.
Jan 16 06:49:55 systemd: icingadb.service failed.
Icinga DB Web version (System - About):
Icinga Web 2 version (System - About):
Icinga Web 2 Version 2.12.1
Git commit cd2daeb2cb8537c633d343a29eb76c54cd2ebbf2
PHP Version 7.3.33
Git commit date 2023-11-15
Get Icinga Support
Icinga Community
Report a bug
Icinga Documentation
Loaded Libraries
icinga/icinga-php-library 0.13.1
icinga/icinga-php-thirdparty 0.12.1
Loaded Modules
doc 2.12.1 Configure
monitoring 2.12.1 Configure
setup 2.12.1 Configure
- Web browser:
Chrome is up to date
Version 120.0.6099.217 (Official Build) (64-bit)
- Icinga 2 version (
icinga2 --version):
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.1-1)
System information:
Platform: CentOS Linux
Platform version: 7 (Core)
Kernel: Linux
Kernel version: 3.10.0-1160.42.2.el7.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 11.2.1
OpenSSL version: OpenSSL 1.0.2k-fips 26 Jan 2017
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Icinga DB version (
icingadb --version):
icingadb --version
Icinga DB version: v1.1.1
Build information:
Go version: go1.20.7 (linux, amd64)
Git commit: 6c8b52f2033cd94466863c92d3df632e3c87743c
System information:
- PHP version used (
php --version):
/opt/rh/rh-php73/root/bin/php --version
PHP 7.3.33 (cli) (built: Jul 25 2022 11:32:44) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.33, Copyright (c) 1998-2018 Zend Technologies
- Server operating system and version:
cat /etc/system-release
CentOS Linux release 7.9.2009 (Core)
Linux 3.10.0-1160.42.2.el7.x86_64 #1 SMP Tue Sep 7 14:49:57 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
