Configure npn for icinga2 on redhat8
Hi team,
actually i do installation for icinga2 and icingaweb2 on RHEL8 and after installing npn and configure it , i got this error
i run npn verification from server side and for that
perl verify_pnp_config --mode=bulk+npcd --config=/etc/icinga2/icinga2.conf --pnpcfg=/usr/local/pnp4nagios/etc/
[INFO] ========== Starting Environment Checks ============
[INFO] My version is: verify_pnp_config-0.6.26-R.44
[INFO] Start Options: verify_pnp_config --mode=bulk+npcd --config=/etc/icinga2/icinga2.conf --pnpcfg=/usr/local/pnp4nagios/etc/
[OK ] Running product is ‘icinga2’
[INFO] Reading /usr/local/pnp4nagios/etc//process_perfdata.cfg
[INFO] Reading /usr/local/pnp4nagios/etc//pnp4nagios_release
[OK ] Found PNP4Nagios version “0.6.26”
[OK ] Configured User is ‘icingaadmin’
[CRIT] User icingaadmin does not exist
although i didn’t add user with name “icingaadmin”
i just create icingaweb2 and icinga for mysql ido , i valid this two files
PKG_REL_DATE=“08-21-2017”
PKG_VERSION=“0.6.26”
PKG_NAME=“pnp4nagios”
Configure Arguments
CONFIGURE_ARGS=
pnp4nagios–0.6.26
Config File for process_perfdata.pl
More info on RRDtool can be found at www.rrdtool.org
process_perfdata.pl timeout in seconds
TIMEOUT = 15
Use RRDs Perl module
USE_RRDs = 1
Path to XML/RRD files
RRDPATH = /usr/local/pnp4nagios/var/perfdata
Location of RRDtool binary
RRDTOOL = /bin/rrdtool
Location of PNP config files
CFG_DIR = /usr/local/pnp4nagios/etc
Use a single RRD database per service
one or more datasources per RRD database
RRD_STORAGE_TYPE = SINGLE
Use multiple RRD databases per service
one RRD database per datasource.
RRD_STORAGE_TYPE = MULTIPLE
Max. interval between samples/updates
RRD_HEARTBEAT = 8460
File with RRA options used to create new RRD files
RRA_CFG = /usr/local/pnp4nagios/etc/rra.cfg
Interval at which PDPs are generated
RRA_STEP = 60
LOG_FILE = /usr/local/pnp4nagios/var/perfdata.log
LOG_LEVEL = 0
XML_ENC = UTF-8
Use this option to reduce disk I/O
XML_UPDATE_DELAY = 0
RRD_DAEMON_OPTS =
STATS_DIR = /usr/local/pnp4nagios/var/stats
PREFORK = 1
GEARMAN_HOST = localhost:4730
REQUESTS_PER_CHILD = 10000
ENCRYPTION = 1
KEY = should_be_changed
can you please support me how to validate this user ?
The PNP module for icingaweb2 is makred as depcreated and will not be developed anymore. Better go for graphite or influxdb nad use the modules that are available for them.
Regards,
Carsten
Thanks for info ,
do you have good doc for graphite installation and configuration for RHEL8 , as i tried this first and i faced a lot of problems , so i looked for npn .
Regards,
Eman
I normaly install influxdb. easier to install and easier to maintain :slight_smile:
Check the howto section, i think there is one for graphite (centos7, but should work for 8 too)
Regards,
Carsten
actually i follow this doc : https://monitoring-portal.org/woltlab/index.php?thread/40288-icinga2-with-influxdb-and-grafana-howto/
but i face issues with grafana ,
do you have another mosule we can configure on influx to show the graphs /
Thanks, Eman
I wrote one on setting up graphite on rhel8 a while back: A distro agnostic guide to Graphite with venv (examples: RHEL8, Debian10, Ubuntu18)
I’ve actually switched to InfluxDB and the Grafana module since then, though. I would say InfluxDB is a far superior TSDB to Graphite (my opinion), but the Grafana module for Icinga is going to take more levels of configuration than Graphite’s (which kinda just works). If you’re stuck somewhere, let us know and we should be able to guide you.
Hi All,
I worked with graphite installation and add configuration on icingaweb2 and on /etc/icinga2/features-enabled/graphite.conf
and i got following
can you advice how can i fix ?
