We want to configure autentication using ldap and assing a role to each user based on member-of ldap field.
It is posible in icinga?
Can anyone help us ?
Best regards,
Emilio J.
Best regards,
Emilio J.
Heyhey,
this is what I found in the docs, maybe those could be a starting point?
Resources - Icinga Web 2 and Authentication - Icinga Web 2
I have finally managed to configure it.
Need to do three steps:
Best regards,
Emilio J.
Hello Emilo,
I am at the same point with less success.
Can you clarify with some examples the points 2 and 3?
I managed to load the groups from AD, but inside the group are not users but roles.
group_member_attribute : LDAP attribute where a group’s members are stored.
Defaults tomember.
What did you use here?
How can I assign groups from the AD to the Roles in Icinga?
Saludos/ Regards,
Christian
Hey @chanti, a late welcome to the forum
Please open a new topic for issues that you are experiencing.
If you comment under older topics, especially if they have been solved already, chances are that your message will be overlooked (like it probably has been) are pretty high.
You can always link back to the relating topic by just adding a link to it in the description.
I hope you managed to resolve your issue by now, if now - feel free to open a new topic!
