Configure Graphite Writer to include only a subset of metrics
I’m using graphite feature to save perfdata of checks and show charts for them later.
Howerver, for certain checks I use data that is pulled from Prometheus. It doesn’t make much sense to save perfdata of this checks in Graphite, since that would only duplicate the efforts.
Is it possible to configure Icinga or Graphite to skip certain metrics?
You can set:
enable_perfdata = true
Or
enable_perfdata = false
In your service object. Its default is true
https://icinga.com/docs/icinga-2/latest/doc/09-object-types/#service
