Hi all,
Can anybody help me ?
In Icinga Director I’ve defined a Basic_Host Template with “hostalive” check command; I’ve also defined a “check disk” Service Template and some other Service Templates. All my hosts are based on the Basic_Host Template and use the check_disk Service Template. All work fine.
My question: is there a way to execute a Service check only if my host is UP ?
Thanks for your help
