Compatibility Matrix
Hi. I need a compatibility matrix of icinga2 on SLES. I think the reason would be not to check myself every version on the OSs.
Unfortunately I couldn’t find any. Could anybody show me if there is any?
TNX
Hi, this one: Icinga » Subscriptions » Support Matrix
you might also want to check this file: icinga2/.github/workflows/linux.yml at master · Icinga/icinga2 · GitHub
Those are the distros currently used for the CICD Pipelines of icinga2, including SLES 15.5-15.7
thanks for the ci link.
