- Director version (System - About):1.10.2
- Icinga Web 2 version and modules (System - About):2.11.4
- Icinga 2 version (
icinga2 --version
):r2.13.7-1 - Operating System and version:Debian 11 Kernel 5.10.0-21-amd64
- Webserver, PHP versions:Apache 2.4.54 PHP 8.2.3
Hi, firstly - this monitoring ecosystem is great, thank you for this!
I prepairing single icinga monitor system in template virtual machine.
Once I was almost done, I was made a virtual machine copy to test in real world.
When I was change hostname I run into problems. Most of them I can trace and fix, but the last one is too deep inside. I have no idea.
Command from Inspect
'/usr/lib/nagios/plugins/check_nrpe' '-A' '/etc/icinga2/pki/cert_nrpe/ca.pem' '-C' '/etc/icinga2/pki/cert_nrpe/cli.pem' '-H' '192.168.1.103' '-K' '/etc/icinga2/pki/cert_nrpe/cli.key' '-c' 'checkcpu' '-a' 'time=25m!!time=15s!!time=5!!crit=82%!!warn=60'
Command is created in director from external script.
The error come when service applying to host:
free(): double free detected in tcache 2
<Terminated by signal 6 (Aborted).>
What is most confusing - rendered comand by Inspect
is working fine in cmd.
The same command work before I deleted old certificates and made new with icinga2 api setup
I don’t have any glue…
Thank for any help.
