- Icinga Web 2 version 2.5.3
- Used modules and their versions
|monitoring|2.5.3|
|setup|2.5.3| - Web browser chrome
- Icinga 2 version used r2.13.5-1
- PHP version used 7.1.18
- Server operating system Centos 7
Trying to revive an old instance with a 2.84 setup. I have patched things together but now on last bit it seems I get an error when doing things in the web application.
icinga2: Failed connect to 127.0.0.1:5665; Connection refused.
I have configured the Icinga 2 API with these values:
icinga2
Icinga 2 API
127.0.0.1
5665
icingaweb2
Validating gives this:
Failed to successfully validate the configuration: Couldn't connect to the Icinga 2 API: Failed connect to 127.0.0.1:5665; Connection refused
I have activated the api in icinga 2 but when I try to restart it I see this error in icinga2 daemon -C:
critical/config: Error: Endpoint object for 'mon.test.salt' is missing.
I am not using zone endpoints.
Does Icinga 2.13 require endpoints and if so what it the minimum setup required. This is a temporary monitoring setup for an in-house dev system. I need shortest path to just monitor some instances.
Also, is there a list somewhere which shows all the versions and their compatible dependencies, like OS > icinga2 > icingaweb2 > mysql > etc.
Please advise, thanks.
cat features-available/api.conf
* The API listener is used for distributed monitoring setups.
object ApiListener "api" {
accept_config = true
accept_commands = true
ticket_salt = TicketSalt
cat conf.d/api-users.conf
* The APIUser objects are used for authentication against the API.
object ApiUser "icingaweb2" {
password = "*****"
// client_cn = ""
permissions = [ "*" ]
