Cluster-zone helath check how to do in director way
Hello team,
I read below docs for health check
cluster-zone with Masters, Satellites and Agents
Need to configure the health check for the cluster-zone in a director approach
Is there any way to achieve this?
Thanks in advance
hello team,
Can anybody help
This is fairly simple.
The clusterzone check command is already inside the ITL, so a kickstart import brings it into the Director.
Then simply add the cluster_zone field to the check command from the drop down menu.
Then create a service template using the check command.
After that create service apply rules to check your different zones.
In case your zones are named exactly as the hosts/endpoints you can simply apply the check. If not put the zone name into the cluster_zone field.
Example for a check for a sattlite zone running on the master:
Example for a check running on the satellite(s) check the master zone connection:
Thanks @log1c for the detailed explanation
