Hi team,
I know the epel-release is required for installation on CentOS, but it seems as if where the Cloudlinux EPEL package is used for Cloudlinux 7, I’m unable to install Incignia 2. I’ve included the logs from running yum install icinga2
below. Any help is appreciated!
Thank you
[root@dingo ~]# yum install icinga2
Loaded plugins: fastestmirror, rhnplugin, universal-hooks
This system is receiving updates from CLN.
Loading mirror speeds from cached hostfile
* EA4: 50.115.17.252
* cpanel-addons-production-feed: 50.115.17.252
* cpanel-plugins: 50.115.17.252
* cloudlinux-x86_64-server-7: xmlrpc.cln.cloudlinux.com
* nux-dextop: mirror.li.nux.ro
icinga-stable-release | 2.9 kB 00:00:00
icinga-stable-release/7/primary_db | 235 kB 00:00:01
Resolving Dependencies
--> Running transaction check
---> Package icinga2.x86_64 0:2.12.1-1.el7.icinga will be installed
--> Processing Dependency: icinga2-bin = 2.12.1-1.el7.icinga for package: icinga2-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: icinga2-common = 2.12.1-1.el7.icinga for package: icinga2-2.12.1-1.el7.icinga.x86_64
---> Package icinga2-bin.x86_64 0:2.12.1-1.el7.icinga will be installed
--> Processing Dependency: libboost_program_options.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: libboost_date_time.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: libboost_thread.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: libboost_context.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: libboost_regex.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: libboost_coroutine.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: libboost_system.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
--> Processing Dependency: libboost_filesystem.so.1.69.0()(64bit) for package: icinga2-bin-2.12.1-1.el7.icinga.x86_64
---> Package icinga2-common.x86_64 0:2.12.1-1.el7.icinga will be installed
--> Finished Dependency Resolution
Error: Package: icinga2-bin-2.12.1-1.el7.icinga.x86_64 (icinga-stable-release)
Requires: libboost_program_options.so.1.69.0()(64bit)
Requires: libboost_coroutine.so.1.69.0()(64bit)
Requires: libboost_thread.so.1.69.0()(64bit)
Requires: libboost_context.so.1.69.0()(64bit)
Requires: libboost_regex.so.1.69.0()(64bit)
Requires: libboost_filesystem.so.1.69.0()(64bit)
Requires: libboost_system.so.1.69.0()(64bit)
Requires: libboost_date_time.so.1.69.0()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[root@dingo ~]# systemctl enable icinga2
Failed to execute operation: No such file or directory
[root@dingo ~]# yum install epel-release
Package matching epel-release-7-6.noarch already installed. Checking for update.
Nothing to do
