Hi. I have a master and a zone “myzone” with two clients A and B. Their configs are in zones.d/myzone/A.conf and zones.d/myzone/A.conf? Both clients define vars.disk["disk"] and use the standard service definition that can be found in conf.d/services.conf. So, this is very basic. Here are the host objects:
object Host "A" {
import "generic-host"
address = "a.b.c.d"
zone = "myzone"
vars.agent_endpoint = name
vars.client_endpoint = name
vars.os = "Linux"
vars.disks["disk"] = {
For host B, it looks similar with the name and address adjusted. The service definition is very basic:
import "generic-service"
check_command = "disk"
vars += config
assign where host.name == NodeName
Both clients are behind a NAT-ted router. Therefore, the master cannot contact them directly. Instead, they connect to the master and are configured to accept configuration updates and commands. Here the zones.conf on the master:
object Endpoint "master.fqdn" {
object Zone "master" {
endpoints = [ "master.fqdn" ]
object Endpoint "A" {}
object Endpoint "B" {}
object Zone "myzone" {
endpoints = [ "A", "B" ]
parent = "master"
global = true
global = true
and on the client A (similar for B):
host = "master.fqdn"
port = "5665"
endpoints = [ "A" ]
parent = "master"
global = true
global = true
The service and template definitions are synced via global-templates, the host files via the zone. That seems to work quite nicely. I can see the files being synced onto the clients in the logs. And icinga doesn’t report any issues. As both A and B are in the same zone, they each get both host object conf files. Thus, I need the assign where host.name == NodeName (as in reality they have different partitions, IPs, services, domains, etc.). I can also see that the checks are executed on the client. But the results are not shown in icingaweb2 under each host. Why? What do I need to change?
I am not using Director.
