I’m looking at an example template for WMI check commands and I would appreciate an explanation of what the different arguments refer to and how you would use them. I understand warning and critical arguments, but the rest are unclear. I was unable to find any documentation explaining this.
Also, is it possible to set the check_drive_size command to send warning and critical alerts for each percentage increased over a threshold? For example, if my warning threshold is anything greater than 90%, can I configure it to send alerts at 91%, 92%, and so on? Rather than receiving only one alert when the threshold is first met.
object CheckCommand "check_wmi" {
import "plugin-check-command"
command = [ PluginDir + "/check_wmi_plus.pl" ]
arguments = {
"--inidir" = "$wmi_inidir$"
"-H" = "$host.name$"
"-A" = "$wmi_authfile_path$"
"-m" = "$check_mode$"
"-s" = "$wmi_submode$"
"-a" = "$wmi_arg1$"
"-o" = "$wmi_arg2$"
"-3" = "$wmi_arg3$"
"-4" = "$wmi_arg4$"
"-y" = "$wmi_delay$"
"-w" = "$wmi_warn$"
"-c" = "$wmi_crit$"
"--nodatamode" = {
set_if = "$wmi_nodatamode$"
