Currently I’m checking vhost URL’s running on a server with check_http. Now I also want to check the number of days an SSL certificate is still valid. This can be done with the check_http module as well using the http_certificate and http_sni.
However when this is configured it will stop checking the vhost URL as described in the manual. To overcome this the parameter --continue-after-certificate can be provided which returns both the URL and the SSL validation. How can I specify this in the Icinga2 config?
For now I have added the vhost URL twice, one to check the URL and one to check the SSL certificate.
