Hello. I use icinga2 since 5 years without any problem, but now…I have a server. Debian 12 stable linux, and installed UniFi Network application program (https://community.ui.com/questions/UniFi-Installation-Scripts-or-UniFi-Easy-Update-Script-or-UniFi-Lets-Encrypt-or-UniFi-Easy-Encrypt-/ccbc7530-dd61-40a7-82ec-22b17f027776)
This “generate” webpage: https://abc.domain.com:8443/manage/account/login?redirect=%2Fmanage
I would like to use icinga to check the validity of the ssl cert, but get error:
“SSL_CERT CRITICAL x.x.x.x: Connection refused” on UI. When try on cli, then working fine.
x.x.x.x is the IP of the abc.domain.com. Why show ip and not the domain name? It’s as if you don’t want to connect to the domain, but to the ip, which really throws an error under cl, when use ip, not domain name.
What could be the problem?
Services.conf:
apply Service “ssl-cert” {
import “1day-service”
check_command = “ssl_cert”
vars.ssl_address = “abc.domain.com”
vars.ssl_port = 8443
vars.ssl_timeout = 120
vars.ssl_cert_warn = 30
vars.ssl_cert_critical = 10
assign where match(“ABC”, host.display_name)
CLI command:
/usr/lib/nagios/plugins/check_ssl_cert -H abc.domain.com -v -p 8443 -c 10 -w 30
Version used (
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.6-1) -
Operating System and version
Debian 12.5 -
Enabled features (
icinga2 feature list
Enabled features: api checker ido-mysql mainlog notification -
Icinga Web 2 version and modules (System - About)
|Icinga Web 2 Version|2.11.4|
|PHP Version|8.2.7|
Loaded Modules
|classic_theme||0.0.0|
|monitoring||2.11.4|
- Config validation (
icinga2 daemon -C
[2024-03-14 16:03:55 +0100] information/cli: Icinga application loader (version: r2.13.6-1)
[2024-03-14 16:03:55 +0100] information/cli: Loading configuration file(s).
[2024-03-14 16:03:55 +0100] information/ConfigItem: Committing config item(s).
[2024-03-14 16:03:55 +0100] information/ApiListener: My API identity: icinga2.telemedia.cc
[2024-03-14 16:03:55 +0100] warning/ApplyRule: Apply rule ‘routeros_status’ (in /etc/icinga2/zones.d/master/services.conf: 410:1-410:31) for type ‘Service’ does not match anywhere!
[2024-03-14 16:03:55 +0100] warning/ApplyRule: Apply rule ‘firmwaresw_status’ (in /etc/icinga2/zones.d/master/services.conf: 443:1-443:33) for type ‘Service’ does not match anywhere!
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 5 UserGroups.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 4 TimePeriods.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 4 Users.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 126 Services.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 18 ServiceGroups.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 16 Zones.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 4 NotificationCommands.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 139 Notifications.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 19 Hosts.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 5 HostGroups.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 14 Endpoints.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 1 ApiUser.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 258 CheckCommands.
[2024-03-14 16:03:55 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2024-03-14 16:03:55 +0100] information/ScriptGlobal: Dumping variables to file ‘/var/cache/icinga2/icinga2.vars’
[2024-03-14 16:03:55 +0100] information/cli: Finished validating the configuration file(s).
