I have a problem that I’m not sure how to debug much further, so I’m hoping someone has ideas. I have a single Windows 10 node that is having issues where 9/10 checks using the check_perfmon executable don’t return any performance data or anything at all for plugin output in icinga. I’m running 2.12.0 on all nodes, and all but one don’t have any issues with the same checks.
In icinga web the plugin output area is empty, there is no performance data visible, and in the debug logs on the master there is no corresponding “debug/InfluxdbWriter” line indicating any performance data is getting written for graphing.
Now, for some reason one check_perfmon check functions fine on this node: 'C:/Program Files/ICINGA2/sbin/check_perfmon.exe' '-P' '\Windows Time Service\Computed Time Offset' '-w' '300000000' '-c' '600000000'
Example of a check that doesn’t return performance data/any stdout are: 'C:/Program Files/ICINGA2/sbin/check_perfmon.exe' '-P' '\PhysicalDisk(0 C:)\Avg. Disk sec/Write' '-w' '1' '-c' '2'
This all being said, even the checks that don’t get any perf data/stdout do get the correct exit code AND when I take the command shown from director in inspect and run it in command prompt or powershell, I get the expected stdout and performance data.
I’m baffled by how I can get the check to return things to stdout running a shell, but its not captured by icinga2 or lost somehow.
There’s no followup here after nearly 1000 views, but did you ever find a solution to this? I’m having the same problem on a Windows Server 2025 client.
The general issue might be a result of permissions. icinga2 is likely running as a different user than the one used to execute check_perfmon during investigation. At least I found that to be the most common problem in such cases.
This seems completely reasonable. What is the best way to make sure the user that executes check_perfmon has permissions. I assumed the user executing that would be the same user the service is running as.
It looks like another post with exactly the same problem here:
I was able to replicate exactly what they were seeing.
Well, the user executing the check_perfmon is the user of the icinga2 service on Windows.
You can edit the service to change the user there.
For security reasons it is not recommended to use a user with too many privileges (say SYSTEM), but it might be what you need here.
Sadly I am not deep enough in Windows to tell you how to create a user with just enough privileges. IfW (Icinga for Windows) use the JEA functionality to do just that and the separate execution service (running the Powershell service) somehow gathers all the needed permissions.
