Hello guys,
I have configured a new icinga cluster in my environment and i ran into some issues with check oracle health command.
The weird thing is that if i run the command from the icinga2 server the command executes just as i expected, however when checking the monitoring result of the same command on my icingaweb2 server i encounter the following error: “cannot connect to xxxx.yyyy ora-12154: TNS: could not resolve the connect identifier specified (DBD ERROR: OciServerAttach)”.
This issue got me really confused.
Would appreciate your help.
Thanks in advance,
Even
