Check_nwc_health privprotocol aes192
Hi Experts,
I am trying to monitor F5 firewall devices using check_nwc_health.
Due to environment requirements, I need to use sha256 and aes192.
While executing the checks, I am getting error:
CRITICAL - cannot create session object: The privProtocol “aes192” is unknown
Could you please help to know how to resolve this ?
Regards
Jay
you can try to patch the GLplugin Perl Module
or use plugin compatible encryption
 --authpassword
   The authentication password for SNMPv3
 --authprotocol
   The authentication protocol for SNMPv3 (md5|sha)
 --privpassword
   The password for authPriv security level
 --privprotocol
   The private protocol for SNMPv3 (des|aes|aes128|3des|3desde)
Thank you for the inputs.
I patched the GLplugin, however, still have the same error.
Do I need to update NET::SNMP or any other packages on my Satellite VM which is running on Rhel ?
Current NET::SNMP version is 5.9.1
Regards
Jay
Can’t see your patch, so I have no idea waht you changed
I am seeing similar issue. Were you able to fix it.
Unknown protocol SHA256.
No. It didn’t.
Later I contacted device vendor and they agreed to release patch to support aes128. However aes192 will be required and will be trying to enabling it later.
