Hello everyone, couldn’t find anything about this issue so I gotta ask.
When I use the “Check Now” in the Icinga Web 2 Interface with Icinga DB I get this error:
No command transports have been configured in "/etc/icingaweb2/modules/icingadb/commandtransports.ini".
But when I go to the terminal to check the file out it does not even exist. So I don’t really have anything else to show you. Sorry about that. There is only a config.ini which states the resource.
