Check MSSQL health with JOBS focus
I need to check the HEALTH of MSSQL on WINDOWS server.
“Icinga for Windows” already in place so I wan to try to use this plugin.
I saw that Icinga for Windows can be enhanced with some PS module to check the Health of MSSQL.
https://icinga.com/docs/icinga-for-windows/latest/mssql/doc/plugins/02-Invoke-IcingaCheckMSSQLHealth/
But there is no “check” for the Scheduled JOB Status .
I’m interested to be alerted if a scheduled JOB fails.
I found this NAGIOS plugin:
Is there a way to integrate this check into “Icinga for Windows” in order to check also the JOB ?
IDEAS ?
P.
Hi @picoroma,
Well, if the functionality is useful, there is a chance to get this integrated. Could you open an Issue for that in the development repository?
That would be the best location for that, the developers would see it and so forth.
Ideally you could contribute an implementation of your idea directly!
OPEN:
THX
P.
Is there a WAY to call on a remote Windows server with “Icinga 4 Windows” installed a .ps1 script from ICINGA Master ?
How should the “command” be defined ?
P.
