Hello everybody,
I have just been made aware that the implemented in Icinga2 script check_mem.pl wrong values.
The script is implemented in the following file: /usr/share/icinga2/include/plugins-contrib.d/operating-system.conf
As an alternative, I once included the check_linux_memory script from https://github.com/hugme/Nag_checks and the values match.
Does anyone happen to have the direct link to download the check_mem.pl script.
We use the script check_mem.pl by Dan Larson (dl@tyfon.net), Justin Ellison (jhustin@techadvice.com)
Thank you for your help
dflach
(crunsher)
2
dnsmichi
(Michael Friedrich)
3
All plugin and CheckCommand definition patches and PRs require docs, including a URL to the original plugin. Yours is documented here.
Hello everybody,
we have found something for the erroneous results.
By calling freem, I got the following result:
free -m
totally used free shared buff / cache available
Mem: 64266 1381 59489 1 3394 62260
Swap: 4095 0 4095
For database systems like Oracle, the same call is set to 0 for the same call
If you comment out the lines 178 - 181 in the script (Buffers | Cached | SReclaimable) the results will be correct again
Or is there another solution …
gkoutsog
(George K)
5
How about an example with both “free -m” and plugin output and explain what you consider wrong, just so we are all on the same page.
Cheers
