Hello everybody,
I have seen that this topic has been discussed several times and for some there was a solution, but unfortunately it doesn’t work for me.
I made a clone of check_http through Icinga2 & Director because I need some arguments in my checks.
This is not the problem, but rather that it doesn’t matter which Check_command I clone that I always come to the result with the same error message that this Check command does not exist.
Is there a sustainable solution for this?
Thanks in advance.
System Info:
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.4-1)
Copyright © 2012-2020 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
System information:
Platform: Ubuntu
Platform version: 20.04.1 LTS (Focal Fossa)
Kernel: Linux
Kernel version: 5.4.0-42-generic
Architecture: x86_64
Build information:
Compiler: GNU 8.4.0
Build host: runner-ltrjqz9n-project-298-concurrent-0
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
