i tried to change my check “disk” to not monitor stuff like /snap/core/…
so i set something like
apply Service “disk” {
import “agent-service”check_command = “disk”
vars += config
vars.disk_cfree = "3%" vars.disk_wfree = "5%" vars.disk_partitions = [ "/" ]vars.disk_all = “true”
vars.disk_local = "true"vars.disk_exclude_type = [“overlay”,“tmpfs”,“nsfs”,“sysfs”,“shm”,“debugfs”,“tracefs”,“nfs”,“squashfs”,“/dev/loop0”,“/dev/loop1”]
vars.disk_ignore_ereg_path = [“/daten/dddocker”,“/run/docker”]
vars.disk_partitions_excluded = [“/dev”,“/mnt/sugarcrm”]
vars.disks[“disk”] = {
disk_partitions = “/”
assign where host.vars.os == “Linux”}
already before my start the disk state was flapping every 30 seconds.
I see in Icinga Web, that the check should be executed every 60 seconds (what is also my config)
every 60 seconds the check is executed as intended only showing “/”
but after 30 seconds there is another disk check executed on this machine.
the timer for seconds since last check starts new.
the timer for seconds until next check stays.
After this check /snap/core/ is displayed again in the list of partions.
I’m searching for advise how to search source of this execution.
Its not happening on any other check then disk.
Service is only configured onetime in from what i can find.
Its happening to all Machines the service is assigned.
BR,
Daniel
