apply Service for (tmp_disks => config in host.vars.tmp.disks) {
import “disk-test”
vars.customer_services = “on”
check_command = “disk_snmp”
vars.disk = “tmp”
vars += config
It checks every 60 minutes.
If the disk is full
checks again after 5 minutes.
mark service WARN/CRITICAL and sending notification.
and checks again after 60 minutes.
my request
Check every 60 minutes
If there is a problem,
check it after 5 minutes.
and check every x minutes until the problem is resolved
import “disk-test”
vars.disk = “tmp”
vars += config
01:00:00 check → Result OK
02:00:00 check → Result OK
03:00:00 check → Result OK
04:00:00 check → Result OK
05:00:00 check → Result WARN/CRITICAL
05:05:00 check → Result WARN/CRITICAL (retry_interval)
05:07:00 check → Result WARN/CRITICAL (xxxxxxxxxxxx = 2m) (check again = problem not resolved)
05:09:00 check → Result WARN/CRITICAL (xxxxxxxxxxxx = 2m) (check again = problem not resolved)
05:11:00 check → Result WARN/CRITICAL (xxxxxxxxxxxx = 2m) (check again = problem not resolved)
05:13:00 check → Result WARN/CRITICAL (xxxxxxxxxxxx = 2m) (check again = problem not resolved)
05:15:00 check → Result WARN/CRITICAL (xxxxxxxxxxxx = 2m) (check again = problem not resolved)
05:17:00 check → Result WARN/CRITICAL (xxxxxxxxxxxx = 2m) (check again = problem not resolved)
05:19:00 check → Result OK (check again = problem resolved)
06:00:00 check → Result OK
07:00:00 check → Result OK
08:00:00 check → Result OK
the retry interval is only to differentiate between soft and hard state changes so no you can’t have that.
I don’t know what kind of applience you try to check via snmp so it’s difficult to evaluate the check interval, but I would suggest to check with 10m and fix the disk issue if you get an alert.
If you get the notification that something is wrong you should check or fix it. If you need to change the check interval it looks like you are hoping that the error resolves itself.
If that is the case you should check the thresholds or upgrade the disks if possible
Create a copy of the service with the different check interval but active checks disabled and use a event hook on the first one to enable the second service via API?
