Check_dns - Problem with OpenSSL library
On a local Linux (SUSE Linux 4.12.14-197.51) server, a check_dns via SSH should be executed.
It is used here plugin check_dns V2.3.3 (Nagios plugins 2.3.3)
When executing the message brings:
Error While Loading Shared Libraries: libssl.so.10
Is this check with OpenSSL 1.1 compatible?
Can you solve it?
An OpenSSL downgrade on the server is not planned
Thx
