I have created custom command in master in /etc/icinga2/zones.d/global-templates/memory.conf file:
object CheckCommand "memory" {
import "plugin-check-command"
command = [ PluginDir + "/check_mem" ]
arguments = {
"-w" = "$warning_mem$"
"-c" = "$critical_mem$"
"-W" = "$warning_swap$"
"-C" = "$critical_swap$"
vars.warning_mem = "80"
vars.critical_mem = "90"
vars.warning_swap = "40"
vars.critical_swap = "60"
Now when I monitor this in the client. It is showing “Check command ‘memory’ does not exist.” in icingaweb2.
NOTE: The icinga2 feature API is enabled in the client.
a1mw
(Manfred W.)
September 24, 2019, 10:42am
2
Is the check script installed on your Icinga2 host? (PluginDir is usualy /usr/lib/nagios/plugins)
Do you use a distributed master/satellite setup? If yes, script should be available on all Icinga2 nodes.
I solved it by doing following:
mkdir -p /var/lib/icinga2/api/zones/global-templates/_etc
chown nagios. /var/lib/icinga2/ -R
Added following in /etc/icinga2/zones.conf
global = true
Comment out following line in /etc/icinga2/icinga2.conf
//include_recursive "conf.d"
Then restarted icinga2
winem
(Marcel Weinberg)
September 24, 2019, 2:16pm
4
glad that you solved the issue.
I just want to mention that you actually do not have to do anything manually in the /var/lib/icinga2 - especially in /var/lib/icniga2/api/zones directory. Of course there are a few very rare limitations but most of them are related to disaster recovery or recovery from failures or the PKI setup. In general it’s a good idea to forget about that path and let icinga2 handle the content.
yes, that should be the case. But strange the path was not there so I had to do it manually.
