Check_by_ssh
Hi!
I have a problem what I cannot managed to solv for days. I cannot use check_by_ssh if I use not nagios user.
Error message is the next:
Remote command execution failed: icinga@host-IP: Permission denied (publickey,​keyboard-interactive).
What I checked already:
On server:
icinga@icinga:~$ ssh host-IP
Last login: Fri Jan 24 12:57:40 2020 from server-IP
icinga@icinga:~$ ssh host-IP “/usr/lib/nagios/plugins/check_users -w 2 -c 5”
USERS OK - 1 users currently logged in |users=1;2;5;0
On client:
icinga@ceg-irattar-backup:~> /usr/lib/nagios/plugins/check_users -w 2 -c 5
icingaconfig files:
command.cfg:
object CheckCommand “by_ssh_users_lib” {
import “by_ssh”
vars.by_ssh_command = “/usr/lib/nagios/plugins/check_users -v -w $by_ssh_users_wgreater$ -c $by_ssh_users_cgreater$”
vars.by_ssh_users_wgreater = “3”
vars.by_ssh_users_cgreater = “5”
services.cfg:
apply Service “users” {
import “generic-service”
check_command = “by_ssh_users_lib”
assign where host.vars.CheckType == “by_ssh” && host.vars.PluginPath == “lib”
object Host “ceg-irattar-backup.bktvsz.justice.hu” {
import “generic-host”
address = “host-IP”
vars.desciption = “ceg-irattar-backup”
vars.os = “Linux”
vars.CheckType = “by_ssh”
vars.by_ssh_logname = “icinga”
vars.PluginPath = “lib”
I have created a user named nagios on host before.
If I set vars.by_ssh_logname = “nagios” then everything is fine.
My problem is I would like to monitor with ssh some host with different user as nagios.
Thank You For Your Help.
Could be failing due to SSH waiting for action on first usage.
Have you tried manually ssh’ing from icinga server/satellite to client with said (not nagios) account?
George
Yes, and I managed to run check command as well.
I can ssh and run check command over ssh in console with icings user, but I received error message as you see in previous write.
I suggest turning on debug log and see what is written there during execution of command.
George
If I see correctly you are missing the publickey that is authorizing your user to log in at the remote machine.
Here is a small tutorial(source: https://www.thomas-krenn.com/de/wiki/Icinga_check_by_ssh_Plugin?xtxsearchselecthit=1#):
On the monitoring server do:
Create a new folder for your keyfiles, e.g. /var/lib/icinga/.ssh and then create the keys (no password!)
cd /var/lib/icinga/
mkdir .ssh
ssh-keygen
Then make the user running Icinga 2 (icinga on CentOS/RHEL/SUSE, nagios on Debian/Ubuntu) the owner of the key folder
chown -R icinga.icinga /var/lib/icinga/.ssh
Then copy the pubkey to the remote host with the user you want to use to monitoring and have created on the
ssh-copy-id -i .ssh/id_rsa.pub user@remotehost_ip/fqdn
Then log in using the public key, no password query should come!
ssh -i /var/lib/icinga/.ssh/id_rsa user@remotehost_ip/fqdn
You don’t really need to create a new user on the remote server, you also can use an existing one, just modify the ssh-copy-id and ssh -i statements above according to the user on the remote host.
After this run the Icinga check_by_ssh from the CLI as the Icinga 2 user:
sudo -u icinga '/usr/lib/nagios/plugins/check_by_ssh' '-C' '/usr/lib/nagios/plugins/check_whatever' '-i' '/var/lib/nagios/.ssh/id_rsa' '-l' 'icinga'
I don’t know what I did wrong.
1.) first step create icinga user on server
root@icinga:/etc/icinga2/conf.d# groupadd -r icinga
root@icinga:/etc/icinga2/conf.d# useradd -r -m -d /var/lib/icinga -g icinga -s /bin/bash icinga
root@icinga:/etc/icinga2/conf.d# passwd icinga
root@icinga:/etc/icinga2/conf.d# su - icinga
2.) Create RSA key pairs
cinga@icinga:~$ ssh-keygen
2.) copy public rsa key to Host
icinga@icinga:~$ ssh-copy-id
3.) For test ssh to Remote host/
icinga@:~>
/CRLT-D exit from host/
4.) for test run check command as icinga on server
root@icinga:/etc/icinga2/conf.d# sudo -u icinga ‘/usr/lib/nagios/plugins/check_by_ssh’ ‘-C’ ‘/usr/lib/nagios/plugins/check_users -v -w 3 -c 5’ ‘-H’ ‘’ ‘-l’ ‘icinga’
USERS OK - 1 users currently logged in |users=1;3;5;0
/I’v received the correct check output/
When I set
host.conf:
address = “<Host_IP>”
vars.os = “Linux”
vars.location = “M3”
vars.location = “BKT M3”
vars.notification[“mail”] = {
users = [ “sandorsz” ]
command.conf:
import “by_ssh”
services.conf:
Unfortunately I received error message:
Remote command execution failed: icinga@10.15.40.26: Permission denied (publickey,​keyboard-interactive).
in debug log:
[2020-01-27 10:21:52 +0100] notice/Process: PID 5374 (’/usr/lib/nagios/plugins/check_by_ssh’ ‘-C’ ‘/usr/lib/nagios/plugins/check_swap -v -w 75% -c 50%’ ‘-H’ ‘’ ‘-l’ ‘icinga’) terminated with exit
code 3
I have no idea what should I do?
If I run check command as nagios user it goes well.
[2020-01-27 10:13:27 +0100] notice/Process: PID 3991 (’/usr/lib/nagios/plugins/check_by_ssh’ ‘-C’ ‘/usr/lib/nagios/plugins/check_users -v -w 3 -c 5’ ‘-H’ ‘<Host_IP>’ ‘-l’ ‘nagios’) terminated with exit cod
e 0
I have read in https://www.thomas-krenn.com/de/wiki/Icinga_check_by_ssh_Plugin?xtxsearchselecthit=1# tutorial that
The setup assumes that Icinga runs under the user nagios:
It is possible that I can run only as nagios user check_by_ssh?
Thank Everyone for help!
On which hosts did you perform steps 1-4?
Step 1 should be done on server host you want to monitor by check_by_ssh (though just a useradd is sufficient)
Step 2-4 should be done on the monitoring server
I have updated my post above.
Then you are still missing the -i parameter in the check execution to use the public key to login without a password.
I took steps 1-4 on icinga server, and I create an icinga user on host before as well. I made connection between the two icinga users. Copy icinga user rsa public key to host icinga user, so I can ssh from icinga server to monitored host without password.
I am really confused.
I have managed to solve the problem. I have connected users wrongly. Icinga2 runs under the user nagios, so the next step solve the problem:
1.) on server
su - nagios
ssh-copy-id icinga@<host_ip>
Connect server nagios user to remote host icinga user.
Thank Everyone for help.
Hi, facing issues
‘/usr/lib/nagios/plugins/check_by_ssh’ ‘-C’ ‘/usr/lib/nagio^Cplugins/check_script.sh’ ‘-i’ ‘/home/icinga/.ssh/id_rsa’ -H ‘hostname’
still asks for password.
what I did in a short note:
On the icinga server:
  1. useradd icinga
    2)ssh-keygen -b 4096 -t rsa -C “icinga@$(hostname) user for check_by_ssh” -f $HOME/.ssh/id_rsa
i dont want to create icinga users on remote hosts.
ssh-copy-id -i $HOME/.ssh/id_rsa root@clientname
  1. i copied pubkey to remote server under /root/.ssh/authorized_keys
  2. icinga@server:/root$ ssh root@remoteserver -----> works
my question is how can i monitor the scripts placed on remote hosts
icinga@server:/root$ ‘/usr/lib/nagios/plugins/check_by_ssh’ ‘-C’ ‘/usr/lib/nagios/plugins/check_script.sh’ ‘-H’ ‘hostname’ -i /home/icinga/.ssh/id_rsa
Password: CRITICAL - Plugin timed out after 10 seconds
– i think it asks me root password here which differs from host to host. whats the best way to work
Why?
Using the root user with a passwordless login is very insecure!
I’m not even sure if it is allowed without further configuration, hence the password query.
I’d say a dedicated monitoring user on the remote host.
Dedicated monitoring user i tried . I tried creating icinga user on remote host and by copying the keys . but for some reason it always asks me password though the pubkey is added.
ssh-copy-id -i $HOME/.ssh/id_rsa icinga@clientname
password:
also when i try to issue password, it doesnot take instead the connection gets terminated,
Well, that is to be expected at this stage.
The remote host/user doesn’t know about the key yet, so it asks for a password.
here is a good how to (german, maybe use google translate if necessary): Icinga2 check by ssh - steviesblog.de
tried in the sameway couple of times it didnot work
icinga@server:~$ ssh-copy-id -i $HOME/.ssh/id_rsa icinga@client
/usr/bin/ssh-copy-id: INFO: Source of key(s) to be installed: “/home/icinga/.ssh/id_rsa.pub”
/usr/bin/ssh-copy-id: INFO: attempting to log in with the new key(s), to filter out any that are already installed
/usr/bin/ssh-copy-id: INFO: 1 key(s) remain to be installed – if you are prompted now it is to install the new keys
Unauthorized access to this machine is prohibited
Press if you are not an authorized user
Password:
Password:
though i copied pubkey manually to the authorized key file on user icinga authorizedkeys and test it always ask me password.
