I installed Icinga (version: r2.11.3-1)
on Ubuntu 16.04.6 LTS. Unfortunately I can’t use a newer version of Ubuntu.
I have a problem with the check check_apt.
The version of check_apt installed is this one:
check_apt v2.1.2 (monitoring-plugins 2.1.2)
Copyright (c) 2006-2008 Monitoring Plugins Development Team
<devel@monitoring-plugins.org>
This plugin checks for software updates on systems that use
package management systems based on the apt-get(8) command
found in Debian GNU/Linux
Usage:
check_apt [[-d|-u|-U]opts] [-n] [-t timeout]
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
--extra-opts=[section][@file]
Read options from an ini file. See
https://www.monitoring-plugins.org/doc/extra-opts.html
for usage and examples.
-t, --timeout=INTEGER
Seconds before plugin times out (default: 10)
-U, --upgrade=OPTS
[Default] Perform an upgrade. If an optional OPTS argument is provided,
apt-get will be run with these command line options instead of the
default (-o 'Debug::NoLocking=true' -s -qq).
Note that you may be required to have root privileges if you do not use
the default options.
-d, --dist-upgrade=OPTS
Perform a dist-upgrade instead of normal upgrade. Like with -U OPTS
can be provided to override the default options.
-n, --no-upgrade
Do not run the upgrade. Probably not useful (without -u at least).
-i, --include=REGEXP
Include only packages matching REGEXP. Can be specified multiple times
the values will be combined together. Any packages matching this list
cause the plugin to return WARNING status. Others will be ignored.
Default is to include all packages.
-e, --exclude=REGEXP
Exclude packages matching REGEXP from the list of packages that would
otherwise be included. Can be specified multiple times; the values
will be combined together. Default is to exclude no packages.
-c, --critical=REGEXP
If the full package information of any of the upgradable packages match
this REGEXP, the plugin will return CRITICAL status. Can be specified
multiple times like above. Default is a regexp matching security
upgrades for Debian and Ubuntu:
^[^\(]*\(.* (Debian-Security:|Ubuntu:[^/]*/[^-]*-security)
Note that the package must first match the include list before its
information is compared against the critical list.
The following options require root privileges and should be used with care:
-u, --update=OPTS
First perform an 'apt-get update'. An optional OPTS parameter overrides
the default options. Note: you may also need to adjust the global
timeout (with -t) to prevent the plugin from timing out if apt-get
upgrade is expected to take longer than the default timeout.
Send email to help@monitoring-plugins.org if you have questions regarding
use of this software. To submit patches or suggest improvements, send email
to devel@monitoring-plugins.org
Unfortunately, in this version (v2.1.2) the –only-critical option is not available.
-o, --only-critical
Only warn about upgrades matching the critical list. The total number
of upgrades will be printed, but any non-critical upgrades will not cause
I need the result of this missing option.
I mean, in case of non-critical updates, I’d like the status to be like this:
APT OK: 6 packages available for upgrade (0 critical updates).
Instead, when there are critical updates I would like a status like this:
APT CRITICAL: 6 packages available for upgrade (3 critical updates).
Can you please give me some advice?
Thanks!
