Hello all,
I have a graphite docker container which is successfully connected to my Icinga2 web. Everything is running fine except that I can’t view graphs exceeding 6 hours. Please who know how I can change this. The helps I have seen so far is for graphite not running on docker.
Regards
It should be the same logic. You can get in there, either docker exec -it yourcontainer /bin/sh, edit the config and run whisper-resize.py (or clear it out since it’s only 6 hours anyway), or use docker cp to transfer files back and forth from /opt/graphite/conf inside the container.
Thanks Blake,
I modified the storage-schemas.conf file to the desired time and deleted the old whisper file since running whisper-resize.py could not find any .wsp file. It’s fine anyways.,
Thank you
they’re down in /opt/graphite/storage/whisper/icinga2 . I would recommend seeking one out and using whisper-info.py just to make sure it’s showing the time series you intended to allocate.
