I have a Icinga Server running. After e reboot of the server. I get in Icingaweb :
It appears as though you do not have permission to view information for any of the hosts you requested…
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI and check the authorization options in your CGI configuration file.
Kind regards
Matthias Kirsch
