Hi there, I am trying to use the ansible-collection-icinga to deploy master, satellites and agents. We have scenarios where the agent cannot connect the master, therefore the satellite needs to be able to sign/provide the certificates. The ca from the master is copied to the satellite and it is up and running.
Today I tried to setup an agent. I see an incoming certificate request from the agent, but it is just stuck on “Waiting for approval.”. I can see the pending request via icinga2 ca list.
Fingerprint | Timestamp | Signed | Subject
xxxx | Apr 25 07:38:58 2025 GMT | | CN = agent.example.net
Log from satellite:
[2025-04-25 09:38:58 +0200] information/ApiListener: New client connection from [::ffff:10.10.10.10]:53856 (no client certificate)
[2025-04-25 09:38:58 +0200] information/ApiListener: No data received on new API connection from [::ffff:10.10.10.10]:53856. Ensure that the remote endpoints are properly configured in a cluster setup.
[2025-04-25 09:39:00 +0200] information/ApiListener: New client connection for identity 'agent.example.net' from [::ffff:10.10.10.10]:53868 (certificate validation failed: code 18: self-signed certificate)
[2025-04-25 09:39:00 +0200] information/JsonRpcConnection: Received certificate request for CN agent.example.net' which couldn't be verified: self-signed certificate (code 18)
[2025-04-25 09:39:00 +0200] information/JsonRpcConnection: Certificate request for CN 'agent.example.net' is pending. Waiting for approval.
[2025-04-25 09:39:00 +0200] warning/JsonRpcConnection: API client disconnected for identity 'agent.example.net'
What step am I missing? I think I am overlooking something in the collection or the general setup.
Vars on agent
- name: api # Enable Feature API
accept_config: true
accept_commands: true
ca_host: "{{ groups['icinga_satellites_int'][0] }}"
cert_name: "{{ inventory_hostname }}"
ticket_salt: "{{ icinga2_global_ticketsalt }}"
force_newcert: yes # set to `yes` in case you need to re-setup a client
# Trusted Cert and Ticket will be gathered from this host.
# Ticket will be "delegated" if the FQDN is not in your Ansible environment
# use the variable icinga2_delegate_host in addition.
endpoints:
- name: NodeName
- name: "{{ groups['icinga_satellites_int'][0] }}"
zones:
- name: NodeName
parent: "{{ icinga2_global_zonename_satellite }}"
endpoints:
- NodeName
- name: "{{ icinga2_global_zonename_satellite }}"
endpoints:
- "{{ groups['icinga_satellites_int'][0] }}"
- name: global-templates
global: true
- name: director-global
global: true
- Version used (
icinga2 --version)- r2.14.5-1
- Operating System and version
- 20.04.6 LTS (Focal Fossa)
- 22.04.5 LTS (Jammy Jellyfish)
- Enabled features (
icinga2 feature list)- master: api checker icingadb mainlog notification
- satellite: api checker mainlog
- agent: api checker mainlog
- Icinga Web 2 version and modules (System - About)
- 2.12.4
- Config validation (
icinga2 daemon -C)- no errors
- ansible-collection-icinga version
- 0.3.4
zones.conf
Master
object Endpoint NodeName {
object Endpoint "satellite.example.net" {
host = "10.10.10.10"
object Endpoint "master2.example.com" {
object Zone ZoneName {
endpoints = [ NodeName, "master2.example.com", ]
global = true
global = true
object Zone "satellite-zoner" {
endpoints = [ "icinga-satellite.example.com", ]
parent = ZoneName
Satellite
object Endpoint "master1.example.net" {
object Endpoint "master2.example.net" {
parent = "main"
endpoints = [ NodeName, ]
global = true
global = true
object Zone "main" {
endpoints = [ "master1.example.net", "master2.example.net", ]
Agent
object Endpoint "satellite.example.com" {
object Zone NodeName {
parent = "satellite-zone"
global = true
global = true
object Zone "satellite-zone" {
endpoints = [ "satellite.example.net", ]
