[x] Exit [c] Continue [h] Help [l] Commands [m] Main
[Error]: Failed to create certificate.
Arguments: pki save-cert --trustedcert C:\ProgramData\icinga2\var\lib\icinga2\certs\trusted-parent.crt --host 10.0.0.55 ::1 --port 5665
rror:critical/cli: Too many arguments. At most 0 arguments may be specified.
[Error]: Unable to connect to your provided Icinga CA. Please verify the entered configuration is correct.
[Error]: Failed to enter menu “Start-IcingaForWindowsInstallation”. Error "Invalid IP-Address format. For IPv6 and/or port configuration, the syntax must be like [ip]:port
[Warning]: The package “agent” with version “2.13.5” is already installed. Use “-Force” to re-install the component
[Warning]: Certificate file desktop-shjoton.crt is not matching the hostname DESKTOP-SHJOTON. Certificate generation is required.
[Warning]: Your Icinga Agent API feature has been disabled. Please provide either your ca.crt or connect to a parent node for certificate requests. You can run “Install-IcingaAgentCertificates” with your configuration to properly create the host certificate and a valid certificate request. After this you can enable the API feature by using “Enable-IcingaAgentFeature api” and restart the Icinga Agent service “Restart-IcingaService icinga2”
Just to very clear here, installing a Icinga2 Server (a controlling instance) is NOT supported on Windows and my not work at. Using Icinga2 as an agent (being controlled remote by a server) though is.
Since I cannot see in the screenshot what the input parameters where, which you chose for this installation I cannot say if there is a problem with, please kindly provide them.
Apart from that, if you did not enter a IP address manually here, there seems to be a bug, where the IP address resolution is somehow faulty.
But then again there is now way to really tell, until you can provide the parameters which you put into it.
