Dear all,
sorry for asking maybe stupid things, but my knowhow related to Icinga and carbon-relay-ng is nearlly zero
We’ve tried to setup the carbon-relay-ng to send data metrics from Icinga to Kafka and that seems to work now, but the format of the data stream arriving on the Kafka Server is poor and looks like that:
Key: Value:��Id�"1.60bbd43ae111c32e6e25dade557ef919�OrgId�Name�<icinga2.test-mock08_test.host.icmp.perfdata.pl.max�Interval<�Value�@Y�Unit�unknown�Time�a�5=�Mtype�gauge�Tags�
Key: Value:��Id�"1.7ef266878bd7f299c9bf4a12272fe3e9�OrgId�Name�Aicinga2.test.host.icmp.perfdata.rtmax.value�Interval<�Value�?o�˯�[!�Unit�unknown�Time�a�5=�Mtype�gauge�Tags�
Key: Value:��Id�"1.2bca5085a41bb2760ab3958cea37d17e�OrgId�Name�Aicinga2.test.host.icmp.perfdata.rtmin.value�Interval<�Value�?j��U����Unit�unknown�Time�a�5=�Mtype�gauge�Tags�
% Reached end of topic monitoring-eventmgmt.stage.icingametrics-json [0] at offset 545145
Does someone know how we can get a properly JSON format without those �?
In parallel we are sending the metrics also to Graphite with carbon and that works fine, same config file carbon-relay-ng.conf
Would be great if someone could help me with that.
Havbe a great day and stay safe
Cheers
Megge
