I have this problem in my web interface, as in the title - both when I click Check now and when I try to open the Source tab, where I see the following stack trace:
Can't send external Icinga command: 401 Unauthorized. Please check your user credentials.
#0 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Command/Transport/ApiCommandTransport.php(301): Icinga\Module\Icingadb\Command\Transport\ApiCommandTransport->sendCommand()
#1 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Command/Transport/CommandTransport.php(111): Icinga\Module\Icingadb\Command\Transport\ApiCommandTransport->send()
#2 /usr/share/icingaweb2/modules/icingadb/application/controllers/HostController.php(89): Icinga\Module\Icingadb\Command\Transport\CommandTransport->send()
#3 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Web/Controller.php(490): Icinga\Module\Icingadb\Controllers\HostController->sourceAction()
#4 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Icinga\Module\Icingadb\Web\Controller->dispatch()
#5 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch()
#6 /usr/share/php/Icinga/Application/Web.php(290): Zend_Controller_Front->dispatch()
#7 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch()
#8 /usr/share/icingaweb2/public/index.php(4): require_once(String)
#9 {main}
Unfortunately I don’t know PHP in any detail; I have already searched extensively, and found this among others, but I don’t really understand whether it relates to my problem.
root@vogon:/var/log/apache2# icinga2 -V
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.7-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
Platform: Debian GNU/Linux
Platform version: 11 (bullseye)
Kernel: Linux
Kernel version: 5.10.0-13-amd64
Architecture: x86_64
Build information:
Compiler: GNU 10.2.1
OpenSSL version: OpenSSL 1.1.1n 15 Mar 2022
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
root@vogon:/var/log/apache2# icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf graphite influxdb influxdb2 livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command icingadb mainlog notification
Modules etc:
Icinga Web 2 Version 2.11.4
Git commit 11453bfa92a70a44efbf7f966f5e7f27e9300a28
PHP Version 7.4.33
Git commit date 2023-01-26
Loaded Libraries
icinga/icinga-php-library 0.11.0
icinga/icinga-php-thirdparty 0.11.0
Loaded Modules
doc 2.11.4 Configure
icingadb 1.0.2 Configure
Copyright © 2013-2023 Icinga GmbH
Browser: Firefox 102.9.0esr (64bit)
root@vogon:/var/log/apache2# php -v
PHP 7.4.33 (cli) (built: Feb 22 2023 20:07:47) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with Zend OPcache v7.4.33, Copyright (c), by Zend Technologies
you need an icinga2 api user with permissions:
https://icinga.com/docs/icinga-web/latest/modules/monitoring/doc/05-Command-Transports/
this user needs to be added in the icingadb module configuration:
OK - I went there and found the monitoring module disabled, so I enabled it. Now I see this error everywhere - this is from when I click the Create a New Command Transport button, but it broke all of the monitoring:
No backend has been configured
#0 /usr/share/icingaweb2/modules/monitoring/library/Monitoring/Backend/MonitoringBackend.php(76): Icinga\Module\Monitoring\Backend\MonitoringBackend::loadConfig()
#1 /usr/share/icingaweb2/modules/monitoring/application/controllers/ConfigController.php(262): Icinga\Module\Monitoring\Backend\MonitoringBackend::instance()
#2 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action.php(507): Icinga\Module\Monitoring\Controllers\ConfigController->createtransportAction()
#3 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch()
#4 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch()
#5 /usr/share/php/Icinga/Application/Web.php(290): Zend_Controller_Front->dispatch()
#6 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch()
#7 /usr/share/icingaweb2/public/index.php(4): require_once(String)
#8 {main}
and the module directory seems rather empty, actually:
# ll /etc/icingaweb2/modules/
total 4
drwxrws--- 2 www-data icingaweb2 4096 Mar 23 14:46 icingadb/
After disabling the monitoring module, things work again, but of course, I can’t run external commands.
rsx
(Roland Sommer)
April 4, 2023, 1:32pm
4
Could you share /etc/icingaweb2/modules/monitoring/commandtransports.ini (of course redacted)?
why enable the monitoring module?
look into the module configuration of the icingadb module
Unfortunately, that file doesn’t exist:
root@vogon:~# ll /etc/icingaweb2/modules
total 4
Sorry, I misunderstood - when I look at the icingadb module command transports, I see that a user is already defined there, which I have called root .
check the password and compare with the api-users.conf
check the permissions of the user
after changing the password or permissions in icinga2 you need to restart the icinga2 service
That user isn’t defined in the web interface - should it be?
I copied the username and password from /etc/icinga2/conf.d/api-users.conf, and the passive checks work fine with these:
root@vogon:/var/log# cat /etc/icinga2/conf.d/api-users.conf
* The ApiUser objects are used for authentication against the API.
object ApiUser "root" {
password = "abcd1234567890"
// client_cn = ""
permissions = [ "*" ]
so if you put this into the icingadb module config, does it work?
host can be 127.0.0.1
port should be 5665 except you changed it
j4n
November 2, 2023, 10:23am
11
Hi - sorry for bumping this topic; my fault for letting it die unresolved, but I’ve been dragged away to other projects.
So, to answer Moreamazingnick - no it still doesn’t work. I copied the info from /etc/icinga2/conf.d/api-users.conf to the icingadb module’s Command Transports:
root@vogon:/var/log/icinga2# cat /etc/icingaweb2/modules/icingadb/commandtransports.ini
[icinga2]
skip_validation = "0"
transport = "api"
host = "localhost"
port = "5665"
username = "root"
I did this through the web interface, and it was accepted there, but I still can’t do things like schedule downtime. Unfortunately there doesn’t seem to be any relevant information in the icinga logs; actually, the message is logged in /var/log/syslog, and it says:
Nov 2 09:48:21 vogon icingaweb2[712880]: Sending Icinga command "actions/schedule-downtime" to the API "localhost:5665"
Nov 2 09:48:21 vogon icingaweb2[712880]: Can't send external Icinga command: 401 Unauthorized. Please check your user credentials.
The odd thing is, these credentials work from all other host reporting via the API.
j4n
November 2, 2023, 10:35am
12
Hah! That last line in my previous reply inspired me to try something: I changed the host = "localhost" to use the actual hostname; I think, in order to get the passive checks to work, I configured icinga to listen on the real IP.
Now it seems to work, and I can run external commands.
Thanks to everyone for your patience.
