Latest versions (August 24th install), icinga2/web/director, on Centos 7.
This issue is probably to do with nagios plugins, more than icinga, but it works from the command line, and isn’t working from icinga.
One of our third party’s servers is reachable by HTTP. I can enter the URL in Chrome and it resolves.
I was trying hostalive, and that didn’t work. I read that hostalive uses an ICMP protocol, and might not respond. So I tried with http.
This command works from the command line with the correct fields substituted in:
check_http -S -H $http_vhost$ -u $http_url$
But when I make this command in Director, and add these fields, and make a host or service template that imports the command, and make a host or service that imports the template, and I fill in the values in the host or service, (the same as I do for everything else, that’s working), I get:
CRITICAL - Socket timeout
Any idea why?
