Hi, for some reason i can not click on the graph but only in the menu you can see in the top of the image.
For compatibility reason i had to use an older version of grafana, as suggested in another question ( maybe up here ).
Should i upgrade icinga and then use the newest version of grafana?
When you use ‘Grafana access=iFrame’ in the configuration of the Grafana module, the graphs are rendered much faster but you have no link to Grafana. My patch adds a link in top of the graph for this.
Otherwise, when you define ‘Grafana access=Indirect Proxy’, you have the link on the graph, but you need the Grafana renderer. The graph then is only an image, which can be used as link and the rendering takes much more time and you no longer have things like tooltips.
Regards
Matthias
