Cannot convert the provided value for argument "SqlPassword" of type "System.String" to type "System.Security.SecureString"
i have a issue with the “Invoke-IcingaCheckMSSQLBackupStatus” command on just one MSSQL Server.
If i execute this command in the icinga cli on the windows system i got a valid response
Invoke-IcingaCheckMSSQLBackupStatus -SqlUsername 'icinga' -SqlPassword (ConvertTo-IcingaSecureString 'password') -SqlHost 'vmtestsql01.domain.de';
But via the icinga server i got an error message
Icinga Exception: Cannot bind parameter SqlPassword. Cannot convert the provided value for argument "SqlPassword" of type "System.String" to type "System.Security.SecureString". CheckCommand: Invoke-IcingaCheckMSSQLBackupStatus Arguments: Hidden for security reasons StackTrace: bei Exit-IcingaExecutePlugin, C:\Program Files\WindowsPowerShell\Modules\icinga-powershell-framework\cache\framework_cache.psm1: Zeile 28383 bei , : Zeile 1
Client Versions
agent        2.14.2    2.14.2
apichecks    1.2.0     1.2.0
framework    1.12.3    1.12.3
mssql        1.5.0     1.5.0
plugins      1.12.0    1.12.0
restapi      1.2.0     1.2.0
service      1.2.0     1.2.0
I also have an exact same vm (Windows Server 2022 and MSSQL 2022) that works perfectly fine.
did you use these baskets / configs to get the commands?:
Yes, and i updated them recently.
Can you please try to remove these two components:
restapi      1.2.0     1.2.0
They are no longer required and could cause some issues regarding on how the arguments are build.
