I am trying to build Icinga from dockerfile here https://github.com/aditosoftware/docker-icinga2
But there is problem with certificates during install, and during icinga2 node wizard
During install:
Creating config file /etc/icinga2/features-available/ido-mysql.conf with new version
checking privileges on database icinga2 for icinga2@localhost: user creation needed.
granting access to database icinga2 for icinga2@localhost: success.
verifying access for icinga2@localhost: success.
creating database icinga2: success.
verifying database icinga2 exists: success.
populating database via sql… done.
dbconfig-common: flushing administrative password
Processing triggers for libc-bin (2.27-3ubuntu1) …
Enabling feature ido-mysql. Make sure to restart Icinga 2 for these changes to take effect.
Module rewrite already enabled
Successfully created configuration directory /etc/icingaweb2
information/cli: Generating new CA.
information/base: Writing private key to ‘/var/lib/icinga2/ca//ca.key’.
critical/Application: Error: getentropy
Additional information is available in '/var/log/icinga2/crash/report.1588086451.173383'
Aborted
Enabling feature command. Make sure to restart Icinga 2 for these changes to take effect.
Disabling feature mainlog. Make sure to restart Icinga 2 for these changes to take effect.
root@icinga2:/# cat /var/log/icinga2/crash/report.1588086451.173383
Caught unhandled exception.
Current time: 2020-04-28 15:07:31 +0000
Application version: r2.11.3-1
System information:
Platform: Ubuntu
Platform version: 18.04.4 LTS (Bionic Beaver)
Kernel: Linux
Kernel version: 3.16.0-10-amd64
Architecture: x86_64
Build information:
Compiler: GNU 8.3.0
Build host: runner-LTrJQZ9N-project-298-concurrent-0
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Error: getentropy
(0) icinga2: icinga::CreateCert(evp_pkey_st*, X509_name_st*, X509_name_st*, evp_pkey_st*, bool) (+0xae) [0x55e859d093ce]
(1) icinga2: icinga::MakeX509CSR(icinga::String const&, icinga::String const&, icinga::String const&, icinga::String const&, bool) (+0x3c1) [0x55e859d0d101]
(2) icinga2: icinga::PkiUtility::NewCa() (+0xde) [0x55e859c0eb0e]
(3) icinga2: icinga::ApiSetupUtility::SetupMasterCertificates(icinga::String const&) (+0xa9) [0x55e859b79cd9]
(4) icinga2: icinga::ApiSetupUtility::SetupMaster(icinga::String const&, bool) (+0x10) [0x55e859b7a820]
(5) icinga2: icinga::ApiSetupCommand::Run(boost::program_options::variables_map const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&) const (+0xcb) [0x55e859b7a94b]
(6) icinga2: <unknown function> (+0x77c8dd) [0x55e859d878dd]
(7) icinga2: main (+0xbe) [0x55e85990f36e]
(8) libc.so.6: __libc_start_main (+0xe7) [0x7f9f46b1eb97]
(9) icinga2: _start (+0x2a) [0x55e85990f3ea]
* This would indicate a runtime problem or configuration error. If you believe this is a bug in Icinga 2
* please submit a bug report at https://github.com/Icinga/icinga2 and include this stack trace as well as any other
* information that might be useful in order to reproduce this problem.
Failed to launch GDB: No such file or directory
root@icinga2:/# icinga2 node wizard
Please specify if this is an agent/satellite setup ('n' installs a master setup) [Y/n]: n
Starting the Master setup routine...
Please specify the common name (CN) [icinga2.docker2.minerva.lt]:
Reconfiguring Icinga...
Checking for existing certificates for common name 'icinga2.docker2.minerva.lt'...
Certificates not yet generated. Running 'api setup' now.
Additional information is available in '/var/log/icinga2/crash/report.1588089005.190064'
Abortedroot@icinga2:/# cat /var/log/icinga2/crash/report.1588089005.190064
Current time: 2020-04-28 15:50:05 +0000
System information:
Platform: Ubuntu
Kernel: Linux
Build information:
Compiler: GNU 8.3.0
General paths:
Internal paths:
Error: getentropy
(0) icinga2: icinga::CreateCert(evp_pkey_st*, X509_name_st*, X509_name_st*, evp_pkey_st*, bool) (+0xae) [0x55f6ca6873ce]
(1) icinga2: icinga::MakeX509CSR(icinga::String const&, icinga::String const&, icinga::String const&, icinga::String const&, bool) (+0x3c1) [0x55f6ca68b101]
(2) icinga2: icinga::PkiUtility::NewCa() (+0xde) [0x55f6ca58cb0e]
(3) icinga2: icinga::ApiSetupUtility::SetupMasterCertificates(icinga::String const&) (+0xa9) [0x55f6ca4f7cd9]
(4) icinga2: icinga::NodeWizardCommand::MasterSetup() const (+0x11b9) [0x55f6ca5036f9]
(5) icinga2: icinga::NodeWizardCommand::Run(boost::program_options::variables_map const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&) const (+0x375) [0x55f6ca503f25]
(6) icinga2: <unknown function> (+0x77c8dd) [0x55f6ca7058dd]
(7) icinga2: main (+0xbe) [0x55f6ca28d36e]
(8) libc.so.6: __libc_start_main (+0xe7) [0x7f97a504fb97]
(9) icinga2: _start (+0x2a) [0x55f6ca28d3ea]
