I’m using build in cluster check. I’ts working well, but if any host (agent) is offline, reports problem “Icinga 2 Cluster Problem: 1 endpoints are not connected” even if this host is acknowledged. Is there whay how tell cluster check to ignore acknowledged hosts? Or can I check only specific list of endpoints?
Thank you
Hello Joseph!
I’m afraid this is the point of the cluster check – to monitor whether the Icinga 2 cluster isn’t disintegrated.
Best,
A/K
