But solution provided there is no good for me, so looking for some best practices.
Issue is that (please note I’m not using Director) when I change scheduled downtime object then I’m landing with 2 downtimes on my service - old one and new one. My current workaround to remove old object (as it’s runtime object) is to disable/re-enable host object.
This is not great because then when I re-enable Host object then I’m loosing history for it in IcingaWeb2 so I don’t have historical data about services etc.
Can somebody advise on better solution to refresh this in case of change?
