Bash script wrapper for check_snmp not providing expected ouput
I’ve written a bash script wrapper for the check_snmp plugin for two of my check commands. I did this with the help of some online resources and existing bash scripts for check_snmp that a previous icinga user in my organization made. Everything in the script looks right to me, but on the icinga2 dashboard it just displays the usage.
Usage: /usr/lib64/nagios/plugins/check_ML3_power.sh [-H ] [-o ] [-C ]
I’m assuming the arguments I’ve defined in my file for the check command itself aren’t being passed properly when the script runs? I must have made an error in the script.
Here’s my bash script:
#!/bin/bash
#Shell script to map default SNMP output to meaningful description
#For Dell EML ML3 Tape Library power supply states
#Exit codes: OK(0), WARNING(1), CRITICAL(2), UNKNOWN(3)
usage() {
echo “Usage: $0 [-H ] [-o ] [-C ]” 1>&2;
exit 3;
while getopts “:H:o:C” option; do
case “${option}” in
H) HOSTIP=${OPTARG};;
o) OID=${OPTARG};;
C) COMMUNITY=${OPTARG};;
*) usage;
esac
done
shift “$((OPTIND-1))”
if [ -z “${HOSTIP}” ] || [ -z “${OID}” ] || [ -z “${COMMUNITY}” ]; then
usage
fi
/usr/lib64/nagios/plugins/check_snmp -H ${HOSTIP} -o ${OID} -C ${COMMUNITY} 2>/dev/null |
awk ‘{print $4}’ |
while read -r line; do
if [[ $line == “2” ]]; then
echo “Power Supply: OK”;
exit 0;
fi
if [[ $line == “3” ]]; then
echo “Power Supply: NOT OK, needs to be checked”;
exit 3;
fi
done
The check command that uses this script (in my commands.conf file):
object CheckCommand “PS1-Status” {
import “plugin-check-command”
command = [ PluginDir + “/check_ML3_power.sh” ]
arguments = {
“-H” = “$address$”
“-C” = “1c1ng@2”
“-o” = “.1.3.6.1.4.1.2.6.257.1.3.2.1.3.1”
“-c” = “3”
“-P” = “2c”
object CheckCommand “PS2-Status” {
arguments = {
“-H” = “$address$”
“-C” = “1c1ng@2”
“-o” = “.1.3.6.1.4.1.2.6.257.1.3.2.1.4.1”
“-c” = “3”
“-P” = “2c”
I’d appreciate any guidance, thanks!
you define in the checkCommand definition the params
“-c” = “3”
“-P” = “2c”
which are not defined in your script
BTW: never post passwords, community strings in public :wink:
I’d recommend to enable debuglog and verify how exactly the plugin is executed.
I just added those two parameters to my script, but the plugin output remains the same.
Solved!
I reviewed the debug log and discovered that the order of my parameters was wrong. Running /usr/lib64/nagios/plugins/check_snmp --help also helped to clarify the proper order for arguments.
Hope this post helps if anyone else runs into this problem. Order of command parameters in the script is important!
Thanks Roland and Stevie for the tips.
