Backend is not running with 2nd master
I’m trying to run a HA Icinga Setup with two masters. I used the official Icinga installation guide for this. But as soon as I configured and started my second master, the backend in Icingaweb2 stops running. I can’t see any issues or error messages which would help me to find the problem.
The icinga2 daemon -C shows no errors.
Could you pls give me an advise how to solve this problem?
Thank you in advance!
regards,
Aaron
Hi @aaron,
do both masters have the IDO feature enabled and write to the same database? If not, have you disabled HA mode in the IDO features config?
Greetings
Noah
hi @nhilverling
thank you for your reply! Both masters have the IDO feature enabled and are supposed to write to the same database. In the ido-mysql.conf file is HA mode set = true.
What else can it be? The message that the Icinga backend isn’t running anymore appears after 1minute of starting the second master. If I stop the second master instance, the backend in Icingaweb turns back to running!
Greetings
What does grep -Fie ido < /var/log/icinga2/icinga2.log say on the 2nd master?
Thx for your reply!
The output from the 2nd master is:
 (0) Reconnecting to MySQL IDO database 'ido-mysql'
[2020-08-12 17:33:40 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[2020-08-12 17:33:42 +0200] information/WorkQueue: #5 (IdoMysqlConnection, ido-mysql) items: 2, rate: 2.63333/s (158/min 690/5min 690/15min);
[2020-08-12 17:33:48 +0200] information/DbConnection: Pausing IDO connection: ido-mysql
[2020-08-12 17:33:48 +0200] information/IdoMysqlConnection: 'ido-mysql' paused.
[2020-08-12 17:33:48 +0200] information/DbConnection: 'ido-mysql' stopped.
[2020-08-12 17:33:48 +0200] information/DbConnection: 'ido-mysql' started.
[2020-08-12 17:33:52 +0200] information/IdoMysqlConnection: 'ido-mysql' resumed.
[2020-08-12 17:33:52 +0200] information/DbConnection: Resuming IDO connection: ido-mysql
[2020-08-12 17:33:52 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'icinga' on 'localhost:3306' failed: "Access denied for user 'icinga'@'localhost' (using password: YES)"
[2020-08-12 17:33:52 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[2020-08-12 17:33:58 +0200] information/WorkQueue: #5 (IdoMysqlConnection, ido-mysql) items: 0, rate: 0.183333/s (11/min 11/5min 11/15min);
[2020-08-12 17:34:02 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'icinga' on 'localhost:3306' failed: "Access denied for user 'icinga'@'localhost' (using password: YES)"
[2020-08-12 17:34:02 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[2020-08-12 17:34:12 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'icinga' on 'localhost:3306' failed: "Access denied for user 'icinga'@'localhost' (using password: YES)"
[2020-08-12 17:34:12 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[2020-08-12 17:34:22 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'icinga' on 'localhost:3306' failed: "Access denied for user 'icinga'@'localhost' (using password: YES)"
[2020-08-12 17:34:22 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[2020-08-12 17:34:32 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'icinga' on 'localhost:3306' failed: "Access denied for user 'icinga'@'localhost' (using password: YES)"
[2020-08-12 17:34:32 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[2020-08-12 17:34:42 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'icinga' on 'localhost:3306' failed: "Access denied for user 'icinga'@'localhost' (using password: YES)"
[2020-08-12 17:34:42 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[root@vmicingamaster2 mssadmin]#
Just another thought, or does it has something to do with the director which I’m running on the 1st master? Is there a special config for running a HA Setup with a working director?
Thx in advance!
Are you sure about that?
:sweat_smile: thats what I thought? The ido_feature is enabled also the ha mode set to true. How and where can I have to fix this?
I’m sorry for this stupid question. I’m still new in the Icinga World.
greetings
In /etc/icinga2/features-available/ido-mysql.conf by specifying the correct host.
hi @Al2Klimov, I’ve specified the 1st master with it’s IP Adress as host. I also looked up for the Grants in the mysql database on the 1st master, to make sure I’ve set the right privileges and password. But I get this error-message
[2020-08-13 16:39:13 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
[2020-08-13 16:39:17 +0200] information/WorkQueue: #5 (IdoMysqlConnection, ido-mysql) items: 6, rate: 1.46667/s (88/min 88/5min 88/15min);
[2020-08-13 16:39:23 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'root' on '172.16.23.62:3306' failed: "Lost connection to MySQL server at 'reading initial communication packet', system error: 0"
Do I miss out something else important? Thank you for your help, I really appreciate it!
greetings,
aaron
Please share the host setting from both masters.
Master2:
object IdoMysqlConnection "ido-mysql" {
 user = "root"
 password = "*6691484EA6B50DDDE1926A220DA01FA9E575C18A"
 host = "172.16.23.62"
 database = "icinga"
 enable_ha = true
Master1:
  //user = "root"
  //password = "*6acfed4de24ae18b7a824573464bce8b438bb51c"
  //host = "localhost"
  //database = "icinga"
  enable_ha = true
Are you sure that’s the right address?
hmmm… I’ve changed the Host settings on the 1st master to the following:
  //user = "root"
  enable_ha = true
But now I get the same error message out of the log as for the second master and the backend stops running in Icingaweb. Even if I uncommented all entries in the file.
I also tried to stop and start the 2nd master, but it doesn’t change the result.
Error log form 1st master now:
    [2020-08-13 18:10:39 +0200] critical/IdoMysqlConnection: Exception during database operation: Verify that your database is operational!
    [2020-08-13 18:10:49 +0200] critical/IdoMysqlConnection: Connection to database 'icinga' with user 'icinga' on '172.16.23.62:3306' failed: "Lost connection to MySQL server at 'reading initial communication packet', system error: 0"
I’m sorry :roll_eyes:
Can you login with the user icinga and password icinga to the mysql database on host 172.16.23.62?
What happens if you do mysql -u icinga -p on the host 172.16.23.62?
What happens if you do mysql -h 172.16.23.62 -u icinga -p on the master server?
Is the root login to the database allowed from external sources, meaning not the db server itself?
Hi @log1c,
On the 1st master (172.16.23.62) I can enter the database with this user: icinga and pw: icinga
On the 2nd master (172.16.23.63) I can’t enter the database with this credentials. Which should be ok?
This on the other hand this doesn’t work on both masters. I cant login from the 2nd master with the credentials user:icinga; pw:icinga, neither from the 1st master.
I get the following error message:
[root@vmicingamaster2 ms]# mysql -h 172.16.23.62 -u icinga -p
Enter password:
ERROR 1130 (HY000): Host 'Icingamaster2' is not allowed to connect to this MariaDB serve
What do you mean by the root login into the database from external source? What did I wrong or how could I fix it?
Do I also have to uncomment the login data on the 1st master in the ido-mysql.conf file, or just on the 2nd master?
Thank you for your help!! :slight_smile:
You have this user in your ido config on master2.
Normally (I think) root can only login from the DB server itself, not from other remote servers.
Also I wouldn’t use the root user for the ido connection.
A login should be working from the second master as well.
So check the user login permissions on the database.
Basic tutorial: https://linuxize.com/post/how-to-create-mysql-user-accounts-and-grant-privileges/
You will need to allow the icinga user to login from the master2 ip and edit your ido config on master2 accordingly.
Hi.
Additionally, please make sure, that a remote login to MySQL (or MariaDB) is allowed.
Caution:
If you change the following, especially the IP, please - previously - make sure, that this has no side effects to anything else using the SQL-Server.
The address has to be changed there, accordingly.
The related files are:
MySQL	: /etc/mysql/mysql.conf.d/50-server.cnf
MariaDB	: /etc/mysql/mariadb.conf.d/50-server.cnf
  • Look for the line starting with “bind-address”. It has to contain the IP which the SQL-Server is reachable at via network.
  • also, please make sure that the line containing “skip-networking” is commented out.
After changes, the SQL-Server has to be restarted.
Another note:
The connecting user has to be allowed to connect remotely.
This can be done by adding a suffix other than localhost (or similar) at creation time.
The suffix can be an IP/Subnet or wildcard, e.g.:
GRANT ALL ON <database>.* TO '<the_user>'@'<remote_ip' IDENTIFIED BY '<the_user_password>';
You can list the users and IPs by:
select user, host from mysql.user;
Greetings
It works!! Thank you all for your help. :slightly_smiling_face:
At the end was it the Remote Login from the correct user. Thank you!
