I have installed icinga on test01(master) and test02(satellite)…The icingaweb2 was working fine untill i setup HA master setup provided in the documentation.
After certificate signing master with satellite the icingaweb started throwing error backend not running.
Can some one please help with this.
test01:
- The db_ido_mysql library implements IDO functionality
- for MySQL.
library “db_ido_mysql”
object IdoMysqlConnection “ido-mysql” {
user = “icinga2”,
password = “*********”,
host = “localhost”,
database = “icinga2”
icinga2 feature list
Disabled features: command compatlog debuglog elasticsearch gelf graphite icingadb influxdb influxdb2 livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker ido-mysql mainlog notification
MariaDB [icinga2]> select status_update_time from icinga_programstatus;
| status_update_time |
| 2022-09-24 17:40:48 |
1 row in set (0.000 sec)
test02:/**
- for MySQL.
user = “icinga2”,
host = “localhost”,
Disabled features: command compatlog debuglog elasticsearch gelf graphite icingadb influxdb influxdb2 livestatus notification opentsdb perfdata statusdata syslog
| 2022-09-24 18:30:44 |
1 row in set (0.001 sec)
