Availability Report - custom state during downtime
is it possible to set a custom state for a service/host during a scheduled downtime?
I want to create an availability report in Grafana and right now Icinga sets the state on warning or critical during a downtime. So its not clear if its a real warning or a warning during a scheduled downtime.
Or do you have any other ideas how to create an availability report where the downtimes are visible?
Thank and Regards
No - Icinga has no concept of “custom states”.
during a scheduled downtime? I want to create an availability report in
downtime.
Indeed - the states reflect the current state of the service / host.
Downtime simply affects whether you get alerts telling you about the state or
not.
downtime.
How are you collecting the state from Icinga?
If you’re looking at a status grid, then you’ll still get the usual red,
yellow, green squares, but in downtime the colours are paler.
If you’re using alert notifications, then you shouldn’t be getting these at all
during downtime - something’s wrong with the configuration if you are.
Create the report based on notifications - these can include the start & stop
of downtime periods as well as “real” alerts outside of downtime.
Remember you can write your own notification scripts, to do anything you like
with the information - you don’t have to just accept the standard basic
scripts which are designed to send emails.
Regards,
Antony.
Thank you Antony. You got the right idea.
I have now created a notification object which reports service state changes, including downtimes, to a Bash script which imports them to InfluxDB and then gets visualized by Grafana.
