I have some servers in AWS and need to get Icinga automatically running when I launch a new instance.
I was hoping I could automate the icinga2 node wizard command. I’ve tried to look online but couldn’t find anything.
Has anyone ever done something like that? Is it possible? if not, is there a workaround?
Thanks @winem, that was really helpful. I’ll get this done using the icinga2 node setup as you mentioned. For now, I’ll mark this question as solved. Thanks again!
I am trying to automate this step with ansible. request the trusted cert from the master
I am calling it from an Agent and would like to send the CSR to it’s Satellite and not the master using the ‘CA-Proxy’ feature. Using the node wizard makes it easy and I tested it on another node I set up as an Agent so it works.
Unfortunately I am not sure of the icinga2 command I need to call to automate this step.
According to this document, how-to-icinga-2-ca-proxy no ca certs are required on the agent when setting up. These seem to be required when making a command line CSR request
Hello @peter.g !
I would suggest that you open a new topic with your issue, as Michael is not active in the forums anymore
I’m sure someone else will be able to help you out as well
Have a nice day!
Feu
