Hello everybody !
I want to develop a playbook to auto deploy an icinga satellite with webui (yes webui is mandatory in my use case).
Do someone know of there is a way to silently configure the webui at first start ?
Thank you for advance ![]()
you can deploy the preconfigured ini files or use the icinga ansible libraries
here is a example from the icinga summit 2024 including a ready to go icingaweb2:
thanks I will try this !
