Hi all,
I’ve been trying to implement pagerduty integration into our icinga2/director but I am having difficulty in getting it working. The documentation for pagerduty has a config file that is to be used as additional configuration in /etc/icinga2 but I would rather have it setup with director instead.
Where I am getting stuck is at getting the array as a custom vars for the notification command.
The documentation shows the output should be:
vars.f_args = [
"SERVICEDESC=$service.name$",
"SERVICEDISPLAYNAME=$service.display_name$",
"HOSTNAME=$host.name$",
"HOSTSTATE=$host.state$",
"HOSTDISPLAYNAME=$host.display_name$",
"SERVICESTATE=$service.state$",
"SERVICEPROBLEMID=$service.state_id$",
"SERVICEOUTPUT=$service.output$"
However in when I try to add the array in Director the preview tab shows the following:
vars.pd_f_args_service = [
"\"SERVICEDESC=$service.name$\", \"SERVICEDISPLAYNAME=$service.display_name$\", \"HOSTNAME=$host.name$\", \"HOSTSTATE=$host.state$\", \"HOSTDISPLAYNAME=$host.display_name$\", \"SERVICESTATE=$service.state$\", \"SERVICEPROBLEMID=$service.state_id$\", \"SERVICEOUTPUT=$service.output$\""
For some reason, it looks like it is adding quotes around the array and I suspect that is why it cannot then read the array but it reads it as a string.
my pd_f_args_service datafield is setup with datatype Array, so I’m not sure what’s going on.
Is this a bug? any help or insight would be appreciated
thanks to all.
