Hi
I’ve a question about icinga2 / nrpe and arguments.
I’ve a configuration with one master and one agent monitored for the moment.
On my master on /etc/icinga2/conf.d/services.conf, I have:
object Service "systemd_service" {
import "generic-service"
host_name = "server1"
check_command = "nrpe"
vars.nrpe_command = "systemd-service"
On my server1, I have on nrpe.cfg:
command[systemd-service]=/usr/lib/nagios/plugins/check_systemd_service --service sshd.service
check_systemd_service is linked with: GitHub - hkbakke/check-systemd-service: Nagios compatible systemd service checker
with this solution, no problem, check is executed and on icingaweb i can see result like:
OK - active since 2022-10-05 11:12:10
I want to do the same but with arguments.
So On my master I tried with many solutions like:
vars.nrpe_arguments = "sshd.service"
And on my server1:
command[systemd-service]=/usr/lib/nagios/plugins/check_systemd_service --service $ARG1$
But with this solution I have
NRPE: Unable to read output
I tried many solutions with
vars.nrpe_arguments = [ "--service", "sshd.service"]
And in this case I have
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
dont_blame_nrpe=1 is on my nrpe.cfg.
Do you have any ideas ?
I tried with other nrpe checks aned arguments but I have the same kind of problems.
